Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
That is typical of all VW Group main dealer spares, they are exactly what they claim to be and never "repair kits" or "service kits". Also after you (I) have worked that out, you (I) go and buy new parts like O-rings to use when replacing an assembly - only to find that in some case everything you need is supplied.Dealer supplied pads don't come with guide pin bolts which I've found mildly annoying the last few times I've changed front and rear pads.
Good adviceYes, I tend to clean up and apply new blue Loctite to callipers that have "bolts with blue Loctite" bolting into guide pins.
Some of these calliper carrier to hub bolts have something similar to NORD-LOCK captive washers on them, so as well being "torque to yield" in the case of the rear ones, I'd always replace if there were any locking elements built into fixings.
The front ones having a 200Nm torque figure, even where not advised to replace, I'd always replace, even if only to get rid of a rusted up headed set of bolts.
After checking an online VW Group web cat, I see that going by part numbers, at least for the 2019 Leon Cupra, a "set of front pads" is just that! So it is a bit of a secret society that you can only get into or use if you have access to a VW Group parts web cat!Dealer supplied pads don't come with guide pin bolts which I've found mildly annoying the last few times I've changed front and rear pads.
The rear pads don't come with the anti rattle shims either - I had to buy some Mintex MBA1679 for my Cupra 280 ST.@nd-photo.nl , I've still that this "rear callipers bracket bolts" bit to experience on my older daughter's 2019 Leon Cupra, new discs, pads and carrier bolts have been bought - I've done this job before on my previous 2000 VW Passat 4Motion, and Polos etc so that means that I've done that job on a car with rear wishbone suspension, but it seems that space is a bit more of a problem with the Cupra rear hub area, getting the car up as high as I can should help with a power bar to achieve the additional angular rotation, now that that car has got its MOT without any issues with the brakes, it will be a summer job I'd guess.
strange:When I bought mine from the forum sponsor Cox Motor Parts back in 2023 they didn't come with them. The parts advisor checked all their boxes of pads and confirmed they weren't included. Cost me £14.15 for 4 delivered which was quite annoying as I could have saved on the postage if I'd known they needed to be ordered separately and could have been included in the original pad and disc order.
I bought them from Pulman VW and neither bolts or shims were supplied in late 2023.Not sure what parts you have brought - but the OEM pads do come with the caliper abutment clips & bolts.
Useful info if in a pinch - but I would always recommend undoing the caliper carrier bolts at each brake service from a corrosion point of view - if left a few years they can get very hard to remove.Just a heads up - when I changed the rear discs on my Cupra 300 - The discs came out without removing the caliper carrier.
Also managed to get the new ones in the same way.
My sons 184tdi with the 272mm rear brakes needed the carrier removing to do his discs.
