2013 6j how to align bonnet with wing?
ukshane2k
7
ive noticed on my sister car the bonnet is correctly aligned on the passenger side but the driverside as a noticeable gap
his there a way to tweak the bonnet to slight get closer on the driverside gap
jamieibizaFR
53
17
If you loosen the 10mm bolt on the wing and give it a little push in and tighten it back up it should slightly close the gap up.
Reactions: ukshane2k
jamieibizaFR
53
17
i give it a try tomorrow hopefully that works
If you need to move the whole wing inwards, there’s another 10mm bolt behind the front triangle glass but that’s a pain to remove. It’s 3 10mm nuts on the other side behind the A post trim. There’s no adhesive holding it in just 3 nuts. DONT DROP THEM
ukshane2k
7
well i just try with the ones i can see under bonnet if that will work if not i will after leave when i got some spare time
Reactions: jamieibizaFR
