Model Year 24/25 Is it possible to activate ACC, Side Assist & Travel Assist on 2024 Formentor?
creixcka
18
Turkiye
First of all hello.
I own a 2024 Cupra Formentor Standart, My vehicle currently has a Lane Assist and Front Assist systems.
I made an quick research about Side Assist and I learned that it works with Ambient Lighting.
For the ACC my car has the radar in the front but in the steering wheel ACC button is blank.
My car has the Lane Assist for the Travel Assist function.
Is it possible to activate all these functions just by codding them?
creixcka
18
Turkiye
In my country there is 2 versions named Standart & VZ-Line
Standart version only have cruise control, Front Assist & Lane Assist
VZ-Line version have the heated seats, ACC, Side Assist and Travel Assist
Because of the high taxes in my country I could only afford to buy the Standard package. This vehicle cost me 50.636,90€ without any functions xD
CupForm
160
84
Bucharest, RO
You mean that you were able to unlock all SFD2 protected modules and make changes? I assume you have an OBD11 with pro license... I'm really curious if you were able to change the Lane Assist to "last setting" (so it doesn't activate each time you start the car) and the new mandatory Speed Warning chime to Off.
For the Side Assist part, also have a look at our "cousins" with Octavias at the link below; I know it's not completely the same system (they have the warning-lights inside the mirror caps), but you'll get a general idea of the work involved. It seems they are currently stuck on the coding part... :unsure:
creixcka
18
Turkiye
Some of them gives error in my car but i changed these settings
Adaptive Lane Guidance
Foglights With DRL
Scandivanian DRL
Lane Assist Memory
I tried to open ACC & Auto Low-High Beams but OBDEleven gave me an error occured message
Reactions: CupForm
First of all hello.
View attachment 49064 View attachment 49065
None of what you’ve just mentioned can be activated on your car with coding alone
Parts are required, and licenses for ACC are required
We can help
SFD2 isn’t implemented on every single control module :)
