AceD909
55
14
Hi everyone,
I need help identifying the correct front top strut mount for my Seat León 1M Cupra R.
Car Details:
  • Model: Leon 1M Cupra R
  • PR Code: G92 (factory sport suspension)
I'm trying to replace the front top mounts, but I’ve run into a big problem:
Problem:
Most online shops say certain mounts are “not for PR-G92” or “not for Cupra R,” and I’m getting conflicting information about which part actually fits the Cupra R’s sport suspension.
Today I checked the top mount currently installed on my car, and it is stamped:
👉 1J0412619C
I tried looking this part number up, but it doesn’t appear in any normal online catalog. Some parts are similar (like 1J0412331C), but 1J0412619C doesn’t show up anywhere, and I don’t want to buy the wrong part.
What I need to know:
  • Has anyone seen 1J0412619C before? Is it an OEM Cupra R / G92-specific top mount?
  • Is this part actually correct for the Cupra R (G92) front suspension?
  • If not, what is the real OEM top mount part number for the Cupra R?
  • What mounts have you successfully used on a Cupra R with PR G92—OEM or aftermarket?
  • Are the standard Leon/Cupra mounts (1J0412331C) safe to use, or will they cause issues on G92 suspension?
Any info, parts diagrams, or personal experience would be massively helpful.
Thanks in advance!
The latest part number for PR: G92 was 1ML 412 331 - but as far as genuine VW Group parts stocking is concerned, that number was dropped 01/02/2022.
So maybe search using that latest part number matching aftermarket offerings.
Hi. On this link: Strut
I can't get them from EBAY, they doesn't ship to my country.
Offerings from "performance leaning" aftermarket suppliers should be made of similar ie harder "rubber" I'd hope.
Even aftermarket(performance/standard) has both 1ML 412 331 and 1J0412331C OE number, I will get cheap one with 1J0412331C and see if they fit, if they doesn't fit i will try to get 1ML 412 331 used or mine repaired.
Difference is 1J0412331C Durometer 50 - 55
1ML 412 331 Leon Cupra R = Durometer 80
Yeah I have heard those powerflex are good but they tend to squeak a little on turns.
