odla
22
Hello, my Cupra Leon plug in hybrid is only 6 ish years old and I see wear and tear already. Some of the sensors are now grey (they were black not long ago) and I can see rust inside the wheels /alloy , the pics attached will show you what I am talking about.
Are you having the same problems?
How do I cover again the sensors? They only need to be covered again because they work fine.
  • Sad
Reactions: Syphon
You'll probably be best off replacing the sensors as they'll come already black, I don't think you can re-paint them as it can impact their operation.
Your wheel hub bells (part of the disc) will need to be cleaned off with a wire brush then painted with a zinc based paint to prevent them from rusting further, or you could replace the discs and pads.
Reactions: Syphon
How much would it be to replace the sensors? The cover has gone but they work fine.
How much would be to clean the rusty things? The hub bells I am worried about.
I do not think these things would be covered by warranty. It is a PCP car, I believe these all go on to wear and tear things
The sensors are painted, they dont have a cover on.
No idea on prices, you'd have to get some quotes.
You'd have to check your warranty paperwork but I'd be doubtful they'd be covered items.
Corrosion on the hub bells is fairly common on the Cupra Leon’s ‘sister’ car - the VW Golf. Brake discs are usually manufactured from cast iron and I dare say the hub bell section has minimal paint applied, hence why they corrode.
Quite a few Golf owners who don’t like the rusty hubs on their cars have repainted them with Hammerite paint which usually lasts at least 2-3 years before signs of corrosion reappears - if it does reappear, then they just repaint them again.
I've got the same rust on my Leon - just over 2 years old. Need to take wheels off and do as SRGTD says but as it's a lease car I am in no rush to do it! Need to borrow a trolley jack from someone and have some warm weather!
My car is also on lease. PCP to be exact.
Contract is expiring in April, do you think the assessor will check these things?
I doubt it. I had an Octavia on lease and it had at least 4 deep scratches and damage to a couple of alloys - assessor said it was perfect! Might have had something to do with the machine polish it was given before handing it back and the fact it was raining!
