Does your infotainment screen creak
  • Total voters
Site Owner
10,659
2,977
South West
www.seatcupra.net
I can't believe I'm the only one with this. I've been a good boy and had a search. My infotainment screen creaks when the car is on the road and it's got worse over time, and I think when it's hot and the dash has expanded slightly. I've narrowed it down to where the unit sits on the dash trim. If I hold it in place it stops. It's annoying and I'm going to try a solution with possibly some rubber / a piece of bike inner tube to tuck under the bottom.
Anyone else have the same? I'm sure it's not specific to the Leon and probably on SEAT's too. If so anyone had a fix?
Vote below please (poll won't work in Tapatalk). It would be helpful once you've voted if you have the issue what car and year you have.
ta
How's that going to fix the infotainment creak? :ROFLMAO: (Sorry couldn't resist it...not experienced the issue though).
Lol I'm open to ideas, Not tried it yet. I've progressed from duct tape at least :)
I'm convinced the bottom of the unit is rubbing with the plastic trim it "floats" above.
I've found that the soft side of stick-on velcro works pretty well if the felt you'd normally use for thinner gaps isn't thick enough - it applies a bit more pressure to stop things rubbing.
Reactions: Syphon
