Or maybe the rear screen has been replaced at some time? If so, the person removing the original (urethane?) seal between the glass and window aperture might have been a bit heavy handed in scraping all traces of the seal off the bodywork before fitting the new screen, removing some of the paintwork in the process.
@Syphon - from what I’ve read on various VAG forums over the years, the success rate for making successful corrosion warranty claims is quite low. For a corrosion warranty claim to stand any chance of success, the corrosion needs to be the result of faulty workmanship or defective materials when the car was built. One of the most common reasons given for declining corrosion warranty claims seems to be the corrosion has been caused by an ‘external influence’, which would likely be the cause if the OP’s car has ever had a replacement rear screen fitted.
