Oct 27, 2026
Hi everyone!
I’m experiencing a strange issue with my 2018 SEAT Leon 5F 1.8 TSI (180 HP, CJSA engine, Xcellence trim), and I’m hoping someone here has experienced something similar.
The symptoms:
  • After switching off the engine, steam starts rising from the lower area of the radiator/cooling fan assembly.
  • The steam usually lasts around 1–2 minutes before disappearing.
  • There is a noticeable sweet smell, similar to coolant.
  • I’m losing approximately 100 ml of coolant per month.
  • The engine has never overheated, and the temperature gauge stays at a steady 90°C.
  • It happens in both dry and rainy weather, although the steam seems more noticeable when it’s raining.
  • I drive approximately 20 km on the motorway every day.
Previous repairs:
In May 2026, the water pump and related components in that area were replaced.
I’ve also noticed that the front heat exchanger, visible through the lower bumper grille, has quite a lot of bent fins from stone impacts. However, I’m not sure whether this is related to the problem.
What I’ve found so far:
I’ve read several forum threads describing very similar symptoms. Some owners reported steam without any coolant loss, while others experienced both steam and coolant loss.
Some mentioned leaking hose connections, clamps, valves or the thermostat housing.
I’m planning to inspect the underside of the car and perform a cooling system pressure test to try to locate the leak.
My questions:
  1. Has anyone experienced steam coming specifically from the lower radiator/fan area after shutting off the engine?
  2. Could a small radiator leak cause these symptoms even if the engine temperature remains normal?
  3. Are there any common coolant connections, hoses or seals in this area that I should pay particular attention to?
  4. Could the steam and coolant loss be two separate issues?
When did it start? "Right" after the waterpump replacement or long after it?
If long after: I suspect a (very) small puncture/leak in the radiator.
I don't think this is a traditional coolant leak where the pump or thermostat is the issue. But you can double check if you see any dried up coolant (whiteish residue) around the coolant cap.
I expect your bottom inspection will show you the issue (in combination with the leak test) 👍
Reactions: tracktoy
After 2–3 weeks of observation, it has been confirmed that there is no steam coming from the engine bay in dry weather. Steam only appears after driving in rainy or humid conditions (caused by rainwater evaporating off the hot radiator/engine components). Additionally, the coolant level remains stable in the middle between the MIN and MAX marks, with minor fluctuations likely due to normal thermal expansion. No coolant leak is present.
