Love the photos ! Are those wheels the standard 18" DEFIER ones and is there an aerodynamic cover over the alloy ?
Thanks, cracking car you will love it! They are standard alloy wheels not an aero cover. One of the nicer looking available wheels and suit the car well. They also give the best ride firm but soak up our moon surface type roads very well too the bonus being harder to curb.
An OTA update is happening as I type this.
The car advised this will take 50 minutes, during which time I mustn't touch it. On pressing OK to accept, exit vehicle, lock the doors (don't leave any persons or pets in there), come back in an hour.
Exciting, isn't it!!
Reactions: JonnyG
Mine went all ok the second time of trying but car worked better with the old 6.0.0
Keep loosing Wi-Fi connection so cannot use app on phone to preheat in the morning.
When you power the car up it connects again. I think it is switching off when the car goes to sleep when left over night.
Now my id buzz is playing up after big update so not having much luck at the moment.
Just got the Cupra app working with apple car play. It does give a few good controls with in car play.
You can set two favourite climate set ups which is handy i have one with it set to off.
Update was to 60.0.1. It completed in the time advertised, then the system rebooted itself, doesn't seem to have lost any personalisation settings and the digital key is still working. Sat Nav restarted and correctly placed us on the map, Android Auto and the S23 phone all connected back up.
Going for a drive this lunchtime so it will get an hour or so run time.
So far so good!
Reactions: JonnyG
Still working - yay!
Also discovered that there are settings to enable climate control upon unlocking the car - this was set to ON, with air conditioning and the heated steering wheel but not the seats. This explains why the last few days (its been cooler outside) that the wheel was on when getting in. It may also explain why it appeared to turn on the wheel when putting on the mirror heaters - as usually the sequence was get in - notice fogged mirrors so activate, then grab the wheel to move off. The wheel was therefore heating from unlock.
Have also proven that the phone - S23 std, does NOT have UWB but will still open and start the car using NFC. You just have to put the phone on the trailing end of the front door handle to unlock, then drop it into the charging tray to start the car. So it is feasible to use the phone as a key provided you get close before unlocking (or unlock via the app from afar).
We are 1000 miles in now. A full 100% charge is reporting circa 215 miles range, a mix of country A and B roads and a bit of dual carriageway is returning about that quite accurately.
Reactions: Pmac16 and jezyg
So my next small mod is fitting MK7 Golf metal pedals, for the expensive sum of £10 from Ali Express! It was a gamble as you never know what the quality is like especially on a safety critical element. But the brake pedal was an exact fitting match just remove the OEM rubber one line up holes and slot the metal one on. Throttle was slightly tricker as is it moulded plastic so had to tease the rubber surround over the moulded plastic pedal but fit is firm, tight and safe, as is the brake pedal. I found both supplied pedals were better quality than expected especially when compared to the OEM metal pedals in our Born.
Reactions: StyxTravel
Was there a metal piece for the left footrest? Always annoyed me with the Golf that RHD cars had a plastic piece, but LHD had a nice metalled footrest.
Reactions: jezyg
I am trying to see if I can have the full WAZE navigation on the dashboard, at the minute it just shows the direction box over the cars own navigation. I am not using the cars navigation just WAZE
