Mar 16, 2026
14
I have a 2012 1.6tdi Leon and the heater has stopped blowing hot recently, the air on HI is slightly less cold than LO but still cold. I've checked the inlet and outlet pipes going to and from the heater matrix and both pipes are mildly warm but comfortable to hold. There's also no obvious sounds of stress in the dash when changing from LO to HI. Just wondering if anyone has any advice on where to go from here. Thanks!
Read live data and see what your actual water temperature is. The needle on the dash might say it's at the correct temperature, but when you look at what the sensor sees you could be much lower.
It would indicate the thermostat is stuck open
Just checked briefly, within a few minutes my of my dash hitting 90 degrees my coolant was at 80, the drive was very short so I'm assuming my thermostat isn't stuck up as it was still climbing.
