Nov 23, 2026
I have a 2016 Seat Ibiza 1.0 and not long after I got it, I noticed the volume changing itself when driving. I did some research and found that there was a setting which adjusted the volume based on the speed of the vehicle. I turned this all the way down to 0 to turn it off and that seemed to work and for a good couple of months it didn't do it again. Now within the last week I noticed it started doing it again. I checked the same setting to ensure it hadn't come back on itself and it hasn't. It's still at 0 and there is no other setting to change. Has anyone else experienced this? Am I missing something? Thanks.
Watch the volume number next time it changes. If it moves on its own with the speed setting at 0, something else is sending volume commands, so a worn knob or sticky button is one possibility. Does it also happen parked with the engine running?
No I don't believe it's happened when parked. Only appears to happen when driving. It doesn't happen immediately but say if I'm driving for a good 15 minutes straight it'll happen. One thing I forgot to mention also was that it turns it down itself and it won't let me manually turn it back up for about five minutes. After five minutes, it then releases control back to me and allows me to turn it back up. If using a scale of 100, I normally have my music between a 70-80. When it turns itself down, it goes down to I'd say about a 20, and then after 5 mins, I turn it back up to 70-80. Super weird, never experienced this was another car before but this is my first Seat car so I assume there is something built it (other than the setting already noted).
