Feb 2, 2026
Hey everyone,
Rear boot light on the right side isn't working, tried changing the bulb but no voltage, left side works fine, measured 12V. Removed the boot trim and all looks good with the wiring there.
Any common problems with the wiring somewhere ? It's been intermittent from the beginning.. now never works.
Ordinary rear lights to the left & right of the trunk works.
Also the light switch, when pressing the switch for the fog lights is it supposed to stay in or pop out ? No reaction on instrument panel, neither front or rear fog lights work.
Attaching pictures, thanks :)
Dont know the answer but have you run a diagnostic scan to see what DTC codes are being shown.
Nevermind the fog lights, you pull the knob out to activate them. :rolleyes:
Borrowed an adapter and used an app called Car Scanner, ran everything but no fault codes.
Guess i'll just follow the cable, ran through the right rubber grommet by the hinges, i'll follow it from there.
I'll keep you updated if i'm successful.
Reactions: Rob66
Sounds simple but double check the bulb is fitted correctly. I recall the outer ones can be a pain.
