Nov 22, 2025
Hello, I currently own a 2008 Cupra K1. The car runs and drives pretty well, occasionally hunts at idle. I believe this is due to the intake air leak which I'm currently chasing. I have also changed both coolant temp sensors, which didn't sort anything. I'm just looking for some advice if anyone else has ever dealt with any of these codes.
Thank you in advance.
Address 01: Engine
9 Faults Found
008504 - Accelerator Position Sensors (G79) / (G185)
P2138 - 008 - Implausible Correlation - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 259333 km
Time Indication: 0
Date: 2000.00.00
Time: 18:27:42
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 30.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.065 V
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 002 - Signal too High
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 259333 km
Time Indication: 0
Date: 2000.00.00
Time: 18:27:44
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 30.0°C
Voltage: 12.065 V
001152 - Coolant Fan Control Circuit 1
P0480 - 002 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 95
Reset counter: 255
Mileage: 259340 km
Time Indication: 0
Date: 2000.00.00
Time: 19:11:21
Freeze Frame:
RPM: 1824 /min
Load: 32.9 %
Speed: 48.0 km/h
Temperature: 75.0°C
Temperature: 24.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.351 V
008801 - Boost Pressure Control Valve (N249)
P2261 - 008 - Mechanical Malfunction
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 71
Reset counter: 255
Mileage: 259340 km
Time Indication: 0
Date: 2000.00.00
Time: 19:11:54
Freeze Frame:
RPM: 2718 /min
Load: 11.4 %
Speed: 54.0 km/h
Temperature: 64.0°C
Temperature: 13.0°C
Voltage: 14.351 V
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 259412 km
Time Indication: 0
Date: 2000.00.00
Time: 00:32:59
Freeze Frame:
RPM: 862 /min
Load: 15.7 %
Speed: 17.0 km/h
Temperature: 71.0°C
Temperature: 31.0°C
Voltage: 14.097 V
001287 - Idle Control System RPM
P0507 - 001 - Higher than Expected. - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 48
Reset counter: 255
Mileage: 259415 km
Time Indication: 0
Date: 2000.00.00
Time: 09:28:56
Freeze Frame:
RPM: 1309 /min
Load: 13.3 %
Speed: 0.0 km/h
Temperature: 66.0°C
Temperature: 22.0°C
Voltage: 14.478 V
008825 - Leak in Air Intake System
P2279 - 002 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 259428 km
Time Indication: 0
Date: 2000.00.00
Time: 10:19:43
Freeze Frame:
RPM: 795 /min
Load: 14.1 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 36.0°C
Voltage: 13.970 V
001089 - EVAP Emission Control Sys
P0441 - 001 - Incorrect Flow - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 259584 km
Time Indication: 0
Date: 2000.00.00
Time: 08:04:47
Freeze Frame:
RPM: 839 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 85.0°C
Temperature: 35.0°C
Voltage: 13.843 V
004688 - Fuel Level too Low
P1250 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 260821 km
Time Indication: 0
Date: 2000.00.00
Time: 11:05:28
Freeze Frame:
RPM: 1303 /min
Load: 12.9 %
Speed: 0.0 km/h
Temperature: 66.0°C
Temperature: 22.0°C
Voltage: 14.351 V
Readiness: 0000 0000
Address 09: Cent. Elect.
1 Fault Found
01334 - Door Control Module; Rear Right (J389)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 225
Mileage: 259415 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.80 V
OFF
ON
OFF
OFF
OFF
Address 16: Steering wheel
5 Faults Found
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Address 19: CAN Gateway
2 Faults Found
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 259333 km
Time Indication: 0
Date: 2000.00.00
Time: 19:05:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 225
Mileage: 259333 km
Time Indication: 0
Date: 2000.00.00
Time: 19:05:12
Address 46: Central Conv.
2 Faults Found
01038 - Central Locking Thermal Protection
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 61
Reset counter: 229
Mileage: 259384 km
Time Indication: 0
Date: 2000.00.00
Time: 22:55:09
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 231
Time Indication: 0
Air leak will probably cause the idle control issue and the lean on bank 1, maybe even the boost pressure and EVAP fault.
Fix the air leaks, clear the codes and go for a drive to see what returns.
