CHRI55
Yes its been Tango'd
Oct 15, 2006
256
Norfolk
Hi all right I haven't been here for a while for which I apologise.. Life just gets in the way. But I'm in need for some help to maybe get my car running as it should again. If possible.......
I know she is an old boat now so dependant on cost this might not be worth doing. I understand this fully.
Just to put you in the picture I have recently had my DPF removed and cleaned along with a new battery as I was informed the problems could potentially go away when completed.
So this had Cleared the DPF light but I still gave and engine light and coil flashing light showing. And to make matters worse MOT is end of next month. YEY
Now I have been pushed from pillar to post for several months, most telling me get rid, some wanting to help, but then after spending my money with the above, not interested and after work also some gave unneeded rudeness. I wont name any garages as I'm not here to shame - I just want to potentially get to the bottom of the issues and fix it if possible.
Even if its for another year. its is what it is.
So I do have a very old VAG COM for which I have been trying to give the information to said garages and non is interested at all. Just want to run their Diagostics.
So bellow is what I get when I scan the car based on the Engine issues=
Thursday,27,August,2026,17:47:25:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 72
77
VIN: *****************
01-Engine -- Status: Malfunction 0010
Address 01: Engine (CEG) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 GN HW: 03L 906 022 GP
Component: R4 2,0L EDC G000SG 4664
Revision: 13H01--- Serial number:
Coding: 0050072
Shop #: WSC 00001 067 57207
VCID: 77F7F50506D6651
4 Faults Found:
009571 - Turbocharger Boost Control Position Sensor Circuit
P2563 - 000 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 3
Mileage: 222817 km
Time Indication: 0
Date: 2127.14.31
Time: 20:36:14
Freeze Frame:
RPM: 782 /min
Speed: 0.0 km/h
Voltage: 13.53 V
Lambda: 75.0 %
Lambda: -22.1 %
Bin. Bits: 00001110
Voltage: 2.280 V
009258 - Exhaust Gas Temperature Sensor; B1 S3
P242A - 000 - Malfunction - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 15
Mileage: 222820 km
Time Indication: 0
Date: 2127.14.31
Time: 01:05:50
Freeze Frame:
RPM: 782 /min
Speed: 0.0 km/h
Voltage: 13.76 V
Temperature: 76.5 C
Temperature: 162.0 C
Temperature: 930.0 C
Temperature: 270.0 C
P242A - 000 - Malfunction - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 69
Mileage: 222820 km
Time Indication: 0
Freeze Frame:
RPM: 897 /min
Speed: 13.0 km/h
Voltage: 13.91 V
Temperature: 75.6 C
Temperature: 198.0 C
Temperature: 120.0 C
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 222826 km
Time Indication: 0
Date: 2127.14.31
Time: 07:12:12
Freeze Frame:
RPM: 2760 /min
Speed: 93.0 km/h
Load: 100.0 %
Absolute Pres.: 2499.0 mbar
Absolute Pres.: 1734.0 mbar
Lambda: 82.9 %
Lambda: 75.8 %
Readiness: 1 3 0 0 0
Thank you for your time. And appreciate any anyone's help. Please by all means be blunt with me. And sorry if this has been brought up many times before.
Cheers. Chris.
  • Sad
Reactions: Momochi
Hi mate. Not an expert on diesels by any means, but seems the first code is related to the variable vanes in the turbochrger. May be that they are all gunked up with carbon. https://wiki.ross-tech.com/wiki/index.php/18995/P2563/009571 I know people used to use Mr muscle oven cleaner to clean them, but there are also specialist products that do the same job. Not sure of the turbo location in your car, but if you can get to it that may be worth a shot.
Second code for the exhaust gas temp sensor, I think that is located close to the DPF, again it could be covered in soot or could just be faulty.
