leonlad
1,255
91
london
floored it away from a junction then had a warning saying cruise control was disabled, scanning showed up these two errors
has a sensor gone bad or something more serious ? 1.8 cjsa
2 Faults Found:
15198 - Intake Manifold Flap; Bank 1
P2004 00 [01100000] - Stuck Open
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 63363 km
Date: 2026.10.03
Time: 11:52:03
Engine speed: 2186.75 /min
Normed load value: 14.1 %
Vehicle speed: 100 km/h
Coolant temperature: 101 C
Intake air temperature: 22 C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 14.921 V
Unlearning counter according OBD: 40
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 609 s
MAP_MES_SAE: 65 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.860 V
FAC_TPS_1_SAE: 20.312500 %
FUP_H_SAE: 16670.0 kPa
15197 - Intake Manifold Flap Position Sensor (Bank 1)
P2014 00 [00100000] - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 39
Mileage: 63363 km
Date: 2026.10.03
Time: 11:52:00
Engine speed: 2192.75 /min
Normed load value: 10.2 %
Voltage terminal 30: 14.941 V
STATE_LS_SAE[1]: CL
T_AST_SAE: 605 s
MAP_MES_SAE: 37 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.699 V
FAC_TPS_1_SAE: 19.140625 %
FUP_H_SAE: 16510.0 kPa
With these kinds of errors, just search for the error code and add "vcds" in your search query, like "P2004 vcds". VAG errors tend to be well documented.
P2004 error
Possible Causes
-Vacuum leak
-Faulty Intake Manifold Runner Position Sensor1 (G336)
-Intake Manifold Runner binding or sticking
Possible Solutions
-Replaced failed vacuum line
-Check Intake Manifold Runner Position Sensor 1 (G336) and wiring, see repair manual
-Check Intake Manifold Flap
-Use Output Test
-Perform Basic Setting (Switch Ignition OFF between Output Test and Basic Setting)
This might be relevant to the other error code: https://forums.ross-tech.com/index.php?threads/47469/
P2004 error
cheers i am seeing posts pointing to 06K907386D being the culprit as it drivers fine for a few miles then a cruise control error that shows those errors which sounds more electrical than mechanical, other wise it would just fail from startup
