Nick2008
Onvi tdi-cupra r wannabe!
Aug 22, 2008
283
gloucestershire
Took me airbox off today (will a little help from the old man!) And have replaced it with a shitty max power induction kit that i bought off my mate for a fiver!
I have been wanting to drill holes in the airbox for ages, have no idea how to go about it and am scared of messing it up, have spoke to my dad and he has a 12mm drill piece which I think would be large enough for the holes, do you have to take anything out of the airbox? where abouts on the airbox do you drill the holes and how many? :confused: I no theres a thread on here which relates to this but cant find it, but if i remember its very confusing to follow!! :cry:
drill holes on the front and the side which is in the bottom picture BELOW the airfilter itself... just open it up with the clips, and drill as above.
the aim is to drill holes on the PRE FILTERED side of the air box and not on the side of the engine
EDIT: and just go hole crazy with the drilling
panel filter is the rectangular air filter.
By 'new free flowing', they're probably referring to an uprated item such as those you can buy from the likes of K&N.
oh i see, hmm this is more complicated than I imagined it would be, thought it was just a case of take airbox off, drill holes in it, replace, job done! Do you really need that part?
Folllowed the instructions closely and drilled the exact amount of holes as whats written in the thread, fitted it back on my car today and it has not made the slightest bit of difference, it just sounds exactly the same as berfore :cry:, i dont understand why, the only thing that I can think of is I accidently broke a bit (about 5cm) out of the bottom of the air box when taking out the 'conical tube', feel bit gutted really :confused:
wont really give u much of a noise unless its right near the throttle body, and i dont think performance wise it will be noticable, will make engine run better for longer though...will get noticed in the long run
most people make theirs from ducting from B&Q, or you can get the proper stuff from performance shops/websites (for example http://www.larkspeed.com/index.pl?p=134BNH25&a=i as you can see its well pricey, so B&Q stuff is much cheaper)
it basically is that ducting that goes from around the bumper (you see the lower splitter on yours, well they go there), its secured in place, then the other end of the ducting is secured by the drilled holes, hence the name "cold air feed" to give the air holes cold air to suck in, not air that is warmed by the engine!
it basically is that ducting that goes from around the bumper (you see the lower splitter on yours, well the gay there), its secured in place, then the other end of the ducting is secured by the drilled holes, hence the name "cold air feed" to give the air holes cold air to suck in, not air that is warmed by the engine!
Cheers matey, is there a thread on here with instructions on how to do this?
If the tumbleweed on here is any guide, no-one is doing much modding of mk2 Ibizas any more.
This mod remains as valid as it ever was, although in my view the point about the cold air feed is important. I would not drill the holes in the airbox without also adding a cold air feed, otherwise the extra airflow will all be warm air from under the bonnet, which will give you little or no benefit.
Ok makes total sense , cheers for the reply maybe I'll just leave it alone and sort out a stage 1 instead.
