Scott330
I had an issue with a warning of “front assist not available. Sensor impaired”
So I took it the the dealer. They first said the car needed a big update and it would take several days because the update was so large there is a possibility that it would fail and need to be re-done. Two and a half days later they called to say it’s ready. When I picked it up they told me the car did need the update, but that wasn’t causing the actual problem I was having. A big spider had made a large egg sac between the sensor cover and the sensor. They showed me a picture of it, and it was impressive in a weird, freaky way. No charge for cleaning out the spiders or the update (still under and extended warranty from buying it pre-owned).
Scott
spider insects GIF
