Thanks, from the advice on here i went with part number; 3G0857511AC
This was plug and play on my FL, it does also dim.
I bought it without the 2 plastic covers and reused mine.
Looks great!! This is one I'll have to add to my list.
Reactions: Mo_86
Replaced the tired old centre caps with ones from a mk4, got the black ones rather than the grey.
They are also nice and flat in comparison to the curved old ones.
Reactions: Walone
Upgraded the speakers and did the sound deadening on the inner skins of the doors and added some on the outer skin and the door cards.
Also swapped the headliner and all the trims from white to black and sound deadened the roof as well. Was a long week not gonna lie. Now only a new amp left to add 🎉🎉
After much procrastination, today I carried out a gear shift linkage adjustment. I followed instructions online and I was surprised how quick and easy it is to do the adjustment. Gear shift now feels more precise :)
@ArchNemeziz I always try to find a cost effective solution, and this looked good on paper :) Fortunately it also worked out good in reality. I only had to make 1 small modification in the end as the 2 "stubs" were banging on the subframe under certain conditions.
I havent posted the pictures yet in my build thread. And thanks for commenting on YT 👌
Reactions: gabz and Mo_86
Recently I've installed exhaust tips from AliExpress in Black Chrome color. They are press-fitted and rubber hammer is required in order to fit them properly. They fits very tightly and there is no chance that they will come loose.
If anyone is interested here is an offer. Seller has Chrome and Black Chrome versions. Be aware that 7.6cm diameter version fits Leon 5F exhaust and 7cm is too tight (don't ask how I know :ROFLMAO: ). In the photos is "C0379-Black" variant. https://s.click.aliexpress.com/e/_c4BcEfXd
Bought a copy cupra spoiler and got rid of the maxton lip one.
Fitting is decent and its pretty flexible.
There are very limited options for the ST so was very glad to find this, its also made of ABS and not fibreglass.
It came with the side spoilers but unfortunately they dont fit flush.
Since the stage 2 and RM motors DP install had some unpleasant vibrations/drone even on comfort at cold start as well on highway according to the wife (although personally I didn't feel highway was that bad). I realized the GPF model doesn't have a resonator and with the GPF delete of the DP that makes sense why it got much worse.
So I'm thinking of fitting a Vibrant 17950 resonator to help with it.
Took some pics of the undercarriage today since the neighbor was kind enough to let me use their canal.
The straight resonator should reduce both drone and vibrations as well as lower the sound raspyness to a sweeter bassy level without losing the burbles and pops gained from the GPF delete.
Reactions: nd-photo.nl
Spark plugs change. Apparently local dealership uses NGK plugs too, VW number but same as the new ones I got.
Using @nd-photo.nl fabulous yt video as a guide and got the coil puller for the job. Certainly made me feel at ease when they all came out in 1 piece 😂
