Oh, and while we're on the subject, don't waste your time asking Cupra Customer Care for any help...
I phoned CCC and the agent actually DIDN'T SEEM TO KNOW what a 12v battery was! She relayed my simple question ("What do Cupra regard as an acceptable resting level for a 12 v battery?") to a member of the 'Technical Team', who apparently said that they couldn't tell me and to find my answer by logging into the 'erWin' website. I went to the 'erWin' website and you can't register if you're a private individual!!!! Totally useless.
I emailed Cupra Customer Care with the same simple question and they told me to go to the dealer! Totally useless.
Customer Care = Utterly useless.
They're pretty good at taking tens of thousands of your pounds for one of their products though, aren't they?
How did you get on with this is your battery still performing as before? I had changed my battery but now with the weather temperature dropping the battery charge is falling again overnight, now as before the alternator is outputting 14.3 volts at the battery so I put the battery on charge with an EFB smart charger and it got to 12.5 volts then stopped charging even after quite a lengthy run the battery only charged to 12.6 volts, now I am begining to think its either a parisitic draw or the battery management system is causing the problem.
Cupra Formentor recorded 17k miles and this!
The dealer tested my battery, said it was within acceptable parameters and to contact them if I get a low battery warning light. To be fair, the battery hasn't failed yet and I stopped taking readings.
Hope your battery's okay. What does it read at after a night's rest? Mine would always drop to 12 or 11.9v - and presumably still does.
You've got me thinking - maybe I'll check mine this morning, if I remember.
