MilgeS
8
Hello again, I picked the car up today and am thoroughly pleased with it so far!
I have a few questions, hopefully nothing too complicated :)
1. Is there only a single 12v socket on the car, in the bootspace, nothing at the front end?
2. I have setup the digital key but it seems to only want to work with Samsung Wallet, does it not work with Google Wallet? It's strange because it showed up in Google Wallet first but I had to download Samsung Wallet to get it to actually do anything?
3. SOLVED - This morning I tried again and it downloaded and installed really quickly, maybe mobile signal is better today.
Is the Store notoriously slow? I went to use it and just had a blank screen for ages, luckily I was doing other stuff at the time and it eventually came up with an update of 46mb which I started to download but that only got to about 8% in 20 minutes so I gave up!
4. Is the Smart Card/Digital Key reliable enough as a backup or should I spend £350 on a 2nd physical key, has anyone else bought a 2nd physical key?
5. I have been prompted to input my S-Pin a few times today, not noticed a pattern for these prompts but had a quick research and think it might be when I have locked/unlocked with the key and then unlocked with the app (or vice versa), any ideas please?
6. SOLVED - Managed to get this working after messing around with controls and screen settings somehow.
My passenger seat automatically slides back on exiting the car, but the drivers seat doesn't, is there a setting I've ticked and need to untick for it to happen to both seats?
7. The Digital Key has an option to "share" with other drivers, I read online that someone just adds their account to their partners phone app rather than have 2 separate user accounts to keep it simple, is that the best way for me to let my wife have the digital key?
8. I also seen online that the logos on the mats come off easily, sure enough, I found one of them in the door pocket and another is hanging on by a thread, any advice other than superglue for refixing these please?
That's all for now, I'm sure once I get to charging I'll have a few more questions!
EDIT - 9. When trying to connect to my dashcam over WiFi to view a clip, the Cupra keeps trying to connect to the dashcam WiFi. I'm using a power bank when I connect to the dashcam as that worked in my previous car, how can I make the Cupra "go to sleep" and not interfere with connecting to the dashcam WiFi please?
Thank you for any help and advice :)
For the seat question, the Born owner's manual says Easy Entry is enabled separately for the driver and the passenger, so the driver's toggle is probably just off. Check the seats menu in the infotainment, under settings, and switch it on for the driver side too.
Thank you for your reply, unfortunately both toggles are on, I've tried to toggle them on/off a few times but no luck.
I'm wondering if there's a knack to saving the seat position, maybe it's because I'm using "set 1" and I've done it in the wrong technique, I'll look into that, thank you.
EDIT - After much pressing off buttons and tapping of screens, it's now working, I just need to experiment to find out what actually changed it!!
