tracktoy
Coding and programming DTC Blogs to help with issues
I have listed below in DTC Number order all the DTC Blogs that OBD11 Have so far created and I am updating with links to VCDS WIKI for same code.
I have also added in the Toyota and BMW Codes (although some of these are shared with VAG as well)
For a full list of the VCDS DTC Wiki entries use this link
For a full list of the OBD2 DTC Site use this link you will need to schroll down to the bottom of the article for the full list.
Overview
P0011 – Intake camshaft timing over-advanced (bank 1)
VCDS WIKI
P0012 – Intake camshaft timing over-retarded (bank 1)
VCDS WIKI
P0014 – "B" camshaft timing over-advanced or performance issue. Bank 1
VCDS WIKI
P0016 – Crankshaft & camshaft misalignment (bank 1 sensor “A”)
VCDS WIKI
P0017 – Crankshaft & camshaft misalignment (bank 1 sensor “B”)
VCDS WIKI
P0101 – Mass or volume air flow "A" circuit range/performance
VCDS WIKI
P0102 – Mass or volume air flow "A" Circuit Low
VCDS WIKI
P0113– Intake air temperature sensor 1 circuit high input
VCDS WIKI
P0125 – Insufficient coolant temperature for closed loop fuel control
VCDS WIKI
P0128 – Coolant temperature below thermostat regulating temperature
Mechanic Base
P0135 – Oxygen sensor heater circuit malfunction (bank 1, sensor 1)
Mechanic Base
P0141 – Oxygen sensor heater circuit malfunction (bank 1, sensor 2
VCDS WIKI
P0171 – Fuel trim. System too lean. Bank 1
VCDS WIKI
P0172 – Fuel trim. System too rich (bank 1)
VCDS WIKI
P0174 – Fuel trim. System too lean. Bank 2
VCDS WIKI
P0299 – Turbocharger/Supercharger underboost condition
VCDS WIKI
P0300 – Random/Multiple cylinder misfire detected
VCDS WIKI
P0301 – Cylinder #1 misfire detected
VCDS WIKI
P0302– Cylinder #2 misfire detected
VCDS WIKI
P0304 – Cylinder #4 misfire detected
VCDS WIKI
P0335 – Crankshaft position sensor "A" circuit malfunction
Engine Codes
P0340 – Camshaft position sensor circuit malfunction
VCDS WIKI
P0401 – Exhaust gas recirculation (EGR) flow insufficient detected
VCDS WIKI
P0420 – Catalyst system efficiency below threshold. Bank 1
VCDS WIKI
OBD11 - Toyota info
P0430 – Catalyst system efficiency below threshold. Bank 2
VCDS WIKI
OBD11 - Toyota info
P0440 – Evaporative emission control system malfunction
VCDS WIKI
P0441 – Evaporative emission control system incorrect purge flow
VCDS WIKI
P0442 – Evaporative emission control system small leak detected
VCDS WIKI
P0446 – Evaporative emission control system vent control circuit malfunction
Engine Codes
P0449 – Evaporative emission control system vent valve/solenoid circuit malfunction
Engine Codes
P0455 – Evaporative emission control system gross leak detected
VCDS WIKI
P0456 – Evaporative emission control system very small leak detected
VCDS WIKI
P0496 – Evaporative emission control system flow during a non-purge condition
Engine Codes
P0499 – Evaporative emission control system vent valve control circuit high
Engine Codes
P0500 – Vehicle speed sensor (VSS) Malfunction
Engine Codes
P0521 – Engine Oil Pressure Sensor/Switch Range/Performance
Engine Codes
P0562 – System voltage low
Engine Codes
P1014 – Valvetronic reference eccentric shaft sensor parity error
Engine Codes
P1030, P1017 – Valvetronic system: No adjustment possible
Please note the details of this DTC are at the bottom of the page
P112F – Air mass system
P1176 – Heated catalyst power switch overtemperature condition bank 1
The document states this is a BMW Specific code but it is listed on the VCDS Wiki Page as well
P1290 – Electric wastegate, adaptation: Cold start not learned
P1447 – DMTL, system fault: pump current reaches limit value during valve test
P1449 – DMTL, system fault: Pump current too high during reference measurement
P1632 – Throttle valve adaptation conditions not met
P2000 – NOX trap efficiency below threshold. Bank 1
P2004 - Intake manifold runner control solenoid stuck open. Bank 1
VCDS WIKI
P2121 – Throttle/Pedal position sensor/switch "D" circuit range/performance
P287B00 Shift Fork Calibration Not Learned
P3000 – HV battery malfunction
U0073 – Control module communication bus
Author
tracktoy
Downloads
224
Views
1,765
First release
Last update
