tracktoy
General maintenance Seat Leon Cupra 280 Service Schedule
Work RequiredAt MillageAdditional Notes
6-gear DSG gearbox 0D9: change
the oil and filter
Every 60,000 km
37,300 Miles
Panorama roof: check operation,
clean drains and lubricate guides
After 3 years / max 60,000 km
and then
every 2 years or 60,000 km after that.
Engine Oil FilterFlexible oil change interval then every 18,641 miles / 30,000 km or 2 years
Fixed oil change interval, Maximum every 9320 miles / 15,000 km or once a year
Air FilterEvery 55923 miles / 90,000 km or 6 years
Dust and Pollen FilterEvery 37282 miles / 60,000 km or 2 years
Oil Change ServicePR QI1 - every 5,000km
PR QI2 – every 7,500km
PR QI3 – every 10,000 km
PR QI4 – every 15,000 km
PR Q17 – every 30,000 km
Spark PlugsEvery 37,282 miles / 60,000 km or 4 years
Front axle differential lock oil changeEvery 3 yearsPlease note many main dealers don’t deal with cupra’s and do not understand about the front diff, this needs to be looked after.
Brake fluid and clutch: RenewAfter 3 years (first time) and then every 2 years
Key Fob BatteryWhen warning message shown on the screenCR2032 Battery.
How to video can be found here
Information from User Community
Lambda SensorEvery 49k Miles 80k KmCommon DTC codes for lambda sensor failure include P0130 (O2 Sensor Circuit Malfunction), P0133 (O2 Sensor Circuit Slow Response), and P0420 (Catalyst System Efficiency Below Threshold). These codes indicate various issues related to the oxygen sensor and its performance in the vehicle's exhaust system.
Taken from the Revo vehicle-care-maintenance
Care and general maintenance are important for any vehicle regardless of the state of tune. The further you push your vehicle the more you need to service it. Below are some recommendations for servicing and maintenance.
Recommended
For a stage 1 or 2 vehicles, Revo suggests that you maintain the same service schedule recommended by your vehicle’s manufacturer. Unlike standard air-filters that you replace aftermarket air-filters required routine cleaning in order to correctly function, this needs to be accounted for with your general servicing.
For stage 2+ and higher stage vehicles, Revo highly recommends reducing the service intervals. As you are running more power through the engine, wear is obviously going to increase.
Vehicle use-age has a big effect on general wear and tear. If you use your vehicle on the track or for long distance driving trips; it’s advised to do both pre and post inspection and fluid changes.
Reactions: Syphon
Author
tracktoy
Views
2,648
First release
Last update
5.00 star(s) 1 ratings
