My Homework
FinerDetails
Official SCN Supporter
Here is the SEAT Altea before I started her first ever FD wash yesterday:
Albeit the car is just one month old, its was in the Dealer Show room so had received one wash and wax only. The instructions on collection were "do not wash it, don't even touch it at all". So when collected from the Dealership the car didn't look too clean, and I think the Dealer was a tad embarressed to be handing over a brand new car in such a state.
Washing and Cleaning Preparation
The first task for me is to start to clean, and prepare the car for the Detailing work. As always, I begin by washing the wheels. I washed the wheels first to ensure that any splashes or dirt which may spray onto the bodywork and paintwork can be cleaned away afterwards. First I rinsed the wheels and wheel arches using a pressure washer. Next I used Pinnacle Wheel Gel to clean the wheels, before spraying the wheels and wheels arches with snowfoam in order to ensure they rinse to a streak free finish.
With the wheels clean, I now started the process of cleaning the paintwork and upper sections of the vehicle. The next task is to pre-soak the upper section with snowfoam.
The aim of this is to loosen any surface dirt and dust, before using the pressure washer to rinse the vehicle. This first stage of the upper vehicle wash can in some cases clean the car to almost 98% without any contact. I then applied a second snowfoam layer to the car, and with a lambs wool washmitt and the Pinnacle Bucket with grit guard and dolly he works he way from top to bottom, around the car gently cleaning the upper car panels. All areas likely to carry the greatest amount of dirt and contamination will be cleaned last. This way the car will have the cleanest water, and least likelihood of any surface contamination becoming trapped and/or in contact with the paintwork again.
Once the vehicle has been thoroughly cleaned, I then used the pressure washer to rinse the snow foam away. The next part of the cleaning and preparation stage is the Clay Bar.
I used Pinnacle Ultra Fine Poly clay bar along with Quick Detailer to remove all surface contamination on this paintwork. Once all of the paintwork had been cleaned and prepared for the following stages I applied a further snowfoam layer to ensure all quick detailer has been cleared from the paint.
Next I got Mrs FD to move the car into the garage, as I'd spent the last two hours washing and claying in the rain and didn't particularly want to have to sit on the brand new leather seats:
(too warm with a coat, so here's me completed soaked right through the T-short I was wearing)
Following a very thorough rinsing, I used a Cobra Guzzler Drying towel to pat, and drag the water from the car. The next two tasks of the detail are the final two of the washing and preparation, Firstly I applied a specialised automotive low tack masking tape to all plastics, rubbers and any areas which require protection from the machine polishing stage. Once fully protected I then used a Digital Paint Depth gauge to check the paintwork on the vehicle.
FinerDetails
Paint correction
The first task for me is to establish the level of abrasion required to correct the paintwork to a safe and acceptable level. I always work with safety as the main directive. I will ‘test’ my way starting with the lest abrasive combination of machine foam pad and polish to find the pairing which will provide maximum paint correction coupled to minimum paint level removal. On this particular Detail I chose to use a Lake County CCS Polishing Pad Pad, and Pinnacle Swirl Remover polish. This polish was applied to the paintwork at 1100rpm and worked to correct the paintwork. Some areas saw 1500rpm.
Where higher levels of abrasives combinations are required I always follow the first machine stage with a second one to ensure the surface has been fully refined and corrected to create the best possible results. On this Detail I used a Wolfgang Finishing pad and Pinnacle Advanced Finishing polish applied at 700 Rpm.
FinerDetails
Protection preparation
This particular Detail was all about the extra mile, so extra stages were put into this section of the Detail.
First I applied Klasse All In One using a finesse pad on the porter cable at speed 3.5.
Next I applied Klasse High Gloss Sealant Glaze with a finishing pad at speed 3. This was then left to cure for 30 minutes. Whilst the glaze cured I completed the alloys - see below.
Once the SG had been buffed off I applied DW Wet Wet Wet wax using another finishing pad on the Porter Cable at speed 3.
Protection and Dressings
The final LSP was Swissvax Best of Show applied by hand.
Once the wax has been fully removed and buffed to a high quality shine I began to detail the other exterior features of the vehicle. I use sealants on the alloy wheels to protect from brake dust and dirt build up. I used Klasse AIO and Klasse SG on this Detail. Next I used the two klasse Twins again to clean all of the exterior glass. I will then applied a dressing into the wheel arches, making sure the plastics are left with a finish which will not distract from the Paintwork’s shine and gloss. I then dresses the tyres, using As Finish to leave a finish to compliment the paint colour and preference of the owner. The next task is to clean and protect the exhaust pipe. I used the Klasse Twins for this too!
Interior
I used interior cleaner to clean all hard surfaces. I do not use any aerosol products and feels silicone cans leave a finish which is both greasy and attracts dirt and ruins the car interior’s appearance.
I then used a professional vacuum to remove all loose dirt from the seats, floor mats and storage areas. On this Detail I then used Pinnacle Leather Cleaner to clean the seats and Pinnacle Leather Conditioner to protect and maintain the finish.
Engine Bay
another day, another write up ;)
And lastly, some very quick pictures between thunder storms:
az_mk
Ive only gone and dun it!
Apr 25, 2007
145
Milton keynes!
wow that really is a kn*b out finish! its amazing to see the amount of effort going to a brand new car and youve got it down to a t! good work! where did you learn??
Icehquk
164
Staffs
Looks like sweat to me ;) Well deserved sweat :lol:
Nice job you should teach the stealers!
I intend to go over mine once it arrives. Not sure it'll be quite up to those standards but got a few tips cheers :D
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
thats really smart mate, amazing to see what work needs doing on a new car, obviously not a major amount but I would have expected a lot less anyway mate you got it perfect looks dead smart.
CupraDaft
458
Scotland
It's sacry just how many marks you had on pick up though from the dealers.
I thought about asking my dealer not to clean my car when I picked it up in march but chickened out...wish I had done though.
Your car looks fab and the chrome wing mirrors really look great on it!
