Custom made quickshift
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
I had read a thread before about quickshifts so i decided making 1 was cheaper.
Didnt take very long only a few bits needed and it was fitted.
Standard
Drilled closer to the pivot point
Modified pin
Painted
finished product
fitted
After a 20 minute drive home i found it to be excellent really shorted the throw between gears really happy with what i made.
CupraMVR
Oct 19, 2006
1,371
Crewe Cheshire
I gridded off the pin then drilled and ran a tap thru the inside of the pin so i could bolt it down to the shifter.used thread lock just it make sure it holds
lc_allan
Northern Monkey
Sep 15, 2006
3,389
Can them pins or similar be bought anywhere?, Is there a name for them?.
I wish I could do this but don't have the skills or tools :(
lc_allan
Northern Monkey
Sep 15, 2006
3,389
That's very kind but I'm not sure you can get the pins seperately. Unless anyone knows different?. It would save on getting a Forge one though ;)
MarkE
Acceptable in the 80s
Jul 20, 2003
1,705
Lancaster
www.markeaston.org
Nice job. Does the trick without the expense if you've got the right tools and knowhow. :thumbup:
I seem to remember Dieselgeek used to sell a similar thing - they sent you a modified shifter and you got a partial refund when you sent your standard one back to them.
flappy
Ferociously Rapid
Mar 28, 2007
219
How did you go about setting it up again with the cables? I think one of the cables on mine might be slighly out as 2nd is a little dfficult to engage
CupraMVR
Oct 19, 2006
1,371
Crewe Cheshire
I made a line so it was straight thru both holes and center punched and drilled then plug and play.Ive missed second a few times driving home.think im getting used to it.im missing more changing down gear tho
Dec 31, 2007
1,479
Reading
I'm so tempted to do this on mine. Anyone know how much a standard one is from the stealers? Just in case!! lol. Anyone know why I couldnt do this on a 5 speed?
So you literally drilled a hole directly in line with the two holes already in place?
Presumably Probee the side-to-side is the same, but you drill a hole lower than the one already in place? how much lower did you go?
Thinking about it, even if I messed up the drilling of the hole, I could just put the pin back in the original position and I would just have an extra hole there.
Dec 31, 2007
1,479
Reading
I've just had a look at mine on my car and it looks completely different, so I'll have to take a closer look and see. I have a bad feeling its not going to work though!
