ABS System.
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
How easy/difficult would it be to fit an ABS System onto my 1.4??
Reason Im asking is that I fancy going for a rear axle swap with discs on it and Ive heard with it, it can be rather tailhappy.
Just wondered.
Craig.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
using the right size master cylinder and/or not the flow regulators you should be fine
check out main site as i think F2 Stu did a guide years ago
CraigW
Craig.
Apr 12, 2007
4,607
I have heard you mention the flow regulator things that are fitted on the brake lines on the drum models. Would that help if changing to a rear disc set-up??
From the top of my head Im sure F2 Stu said the car turned rather tail-happy with the conversion.
SWANSWAY CUPRA Dealership
