ESP light stuck on
Jun 7, 2006
2,983
Norfolk, Norwich
So today I go out in my car driving around and I notice my ESP light is on. Realise I can't turn it off. Think nothing off it restart the car still on.
Did a quick search and I'm guessing itsnthe abs pressure sensor modul jobbie. But is there any other things I can check before I go spend the dollar on the main expensive bit?
Also what the cheapest and legit way to fix it?
Am I doing damage driving it as it is? I know ESP isn't working as I nearly slid off the road earlier when gunning it but brakes seem to work!
Any help is greatly appreciated.
Gazza_24
363
I had my light on shortly after I purchased it, it turned out to be the electronic brake control unit or something similar, luckily it was replaced under warranty as I believe it's quite a pricey fix.
I don't think you'll do any damage, I drove mine for some time and the brakes were fine, the only thing was that I could turn the traction control off
Jun 7, 2006
2,983
Norfolk, Norwich
No warranty is up and it was full seat until the garage I bought it from serviced it them selves in April when I bought it. Jabba did the cambelt also and it's mapped.
Hmm is there any part numbers and can I do it my self?
I'll Dave t sere to send me the parts if so
Lee
Deleted member 65851
Had this problem on a car I test drove from a garage in may he seemed like he wasn't bothered about sorting it out so I walked away
Al
7,331
9
Get it scanned to confirm the fault.
If its the brake fault, there is a "cheap" sensor fix for this. Speak to David at SERE to get it - sure its £100-£150 iirc.
jezyg
2,323
21
Derby
2,983
Norfolk, Norwich
ok time to have this bad boy fixed as i might be selling my car.
can some one tell me what parts i need to source and ill get it done!!
cheers guys any help is greatly appreciated
robert_waite
I had mine done recently and there is a repair kit from the dealers. It was about £150 plus the labour. If you speak to your dealer they will know what you need.
