Hello,
Now I have another problem, this time the problem is with the rear window on the driver's side.
When opening it works well, but when closing, even if you hold the button down, it does nothing, it only closes 0,5cm each time.
I have to press the button 30 or 40x to close the window.
I thought it was deprogrammed but I disconnected the battery and then reconnected, programmed again and it is the same.
Sometimes it works well, sometimes something even weirder happens, it closes well but when it gets to the top starts opening again.
Does anyone know what it happening?
Like this but only closing
https://www.youtube.com/watch?v=03uVCisqhT8
Thank you for your help.
