Hey Guys,
Just had the car under diagnostic at the garage and two fault codes are pointing towards the DV (I took it in as the engine management light came on)
Cant remember off the top of my head what the codes were - Will update later.
However, the garage recommended I change the DV, even though it drives fine, albeit with a few hiccups (which he thinks the DV is causing), the bloke said it's definitely worth changing.
With that in mind, and regardless or whether or not his recommendation is sound, I currently have a forge splitter valve on there, will I really notice the difference putting a stock one on instead of that?
The one i have is going for about £175 on Dtweeks - Not too sure how much a stock one is, however i presume much cheaper.
Any recommendations?
