Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
if your going to get a "wooshy" dv get a forge split r. complete atmospheric dv's can cause engine management lights, limp mode and other issues.
forge will give you some noise but will also recirculate and can be adjusted to be stiff or soft to suite the remap you get if you get 1! if you really want full noise you can change the forge to do this but even they say not to in there instructions
first thought it map it.
however, instead of mapping it, then getting FMIC at later date etc then mapping again, why not get FMIC, exhaust (if you don't have one) and DV, TIP and Induction Kit, then just go straight for a stage 2 map
Save a bit of cash that way
I think i decided now.
going to get all the fmic sorted and stuff first then go from there new wooshy dv should keep me
ammused for a while why i save for the remap.
thanks for your help.
