00437 rear parking sensor out
muks11
77
Leicester
Getting a long beep when selecting reverse so I did a vag com check and it comes up with 00437 right rear inner parking aid sensor (G335) 006 short to plus. Does anyone know if this is the driver side or the passenger side?
Richoscos
Richoscos
Apr 7, 2014
452
Hertfordshire
Should be the driver's side mate, but if you get some help from someone you can check which one it is: get your helper to put the car in reverse while you gently touch the sensors, the ones that are working will pulse gently, the broken one won't.
muks11
77
Leicester
If anyone needs to change these they can be accessed from inside the boot. Remove the plastic trim on the rear and then there should be 2 black vents which can also be removed. Once these are out you can reach into the back of the bumper to access the sensor.
