lexu
49
malta
Hi,
Anyone knows if there is a guide for a 1.2tsi spark plug change? Couldn't find anything on this engine.
I was going to just try to pull them but they're hard to pull out and i dont know if i'm doing something wrong.. dont want to break something
Any chance of a picture of your area / setup ?
Hi,
Sent from my SM-G900F using Tapatalk
In 1.2 TSI (CBZB) you have to pull ignition cable of the spark plug (they are fitted vey well, so you have to pull hard), and then unscrew spark plugs with long 16mm socked wrench. Whole operation shouldn`t take you more than 30 min. You have to be carefull with unscrewing spark plugs because you might break the thread)
Thanks for the replies.. yes I mean the ignition cable like the image below. so i just pull them right?
For reference, this is something like what your trying to pull out. Generally, they will be in tight and require a fair amount of force. Usually there is a metal bit near the end to pull on (so you don't pull on the actual cable itself). Effectively your trying to work that rubber seal up a bit at a time (sometimes twisting it side to side as you pull eases it up).
