I've got the 1.2 TSI And I love it. The two engines put out the same bhp. The diesel will have a little more torque and pull in gear but the petrol is very refined (not that the diesel is not) and pulls all the way from 1500 rpm to the red line. The 1.2 certainly feels quicker then the book figures would suggest. The only minus I would say is when fullly loaded and on the motorway, it can feel a little underpowered when in 6th.
MPG wise, the petrol will do between 40-50 MPG but it all depends how you drive it and what sort of journeys you do. I find the 1.2 will struggle to do much above 40 MPG when doing 70-80 on the motorway. Drop this down to 60 and it will nudge 50 MPG. more relaxed A/B road journeys will see mid 40s to 50. My best ever is 53.3 (trip computer) on a 14 mile commute back from work. From reading on here it would appear that diesel is Better but not by a massive amount. With petrol being cheaper, there is not an awfull lot on it.
Another thing to consider is that the diesel obviously has a DPF which CAN become clogged when subject to lots of short journeys. Some suffer from this issue, others don't.
I would say if your doing shorter journeys consider the petrol. More motorway work then maybe the diesel. The best way though, take a drive in both and see what you think![]()
I have a 1.6 TDI Ibiza, I know it's not a Leon but the same engine so I though I'd give my feedback.
Regarding MPG I would say it's not actually much better than the TSI - on the motorway doing about 75mph with cruise control mine will average about 45-46mpg. If you drive like a granny you can get silly mpg from it, highest average for a trip I ever got was 71.2mpg but thats the exception not the rule.
I don't tend to hang about - so my mpg is generally high 40's when not on the motorway. And it was better before i put the 17" wheels on.
So I'd say unless you're doing serious miles, you're probably better off with the TSI.
But definitely try to get a test drive in both and see what you prefer, the Leon's a heavier car so the mpg might be even less!
The petrol engine is lighter which helps make the front end feel lighter and changes direction quicker. The derv is not quite as responsive although both lumps suffer mild turbo lag the TSi picks up better. Both engines can give patchy consumption figures and the TSi is know to eat allot of oil early on and suffer turbo rattle. Although there is a fix for the rattle, case of working out if the slightly more expensive TDi pay's off financially long term as well.
The 1.6TDi we have is 'OK' - the mpg is bettered easily by the octavia, probably because it needs working harder.
I like the 1.2TSi, but it's a little underpowered for the Leon (works really well in the Ibiza)
Specwise, the SE Copa is really good though, it rides really well
Thanks all just ordered 1.2 TSI in candy hope to get it next week![]()
