red chilli
first off hello all great site !
i own a seat ibiza chill 1.4 mpi 97 reg 5dr now when i bought this car it had a blown headgasket
so i got the head checked all a ok ,,, then changed headgasket and timing belt and tensioner oil air and fuel filter and plugs ,it ran when headgasket was blown but only for 12 seconds then would idle really bad and stall,
ive changed all above allthough its running better it still has the same fault ie from cold it runs perfect on idle for 12 seconds then starts hunting rough idle and stalls ,
ive changed ptu o2 sensor 2nd hnd , leads plugs dizzy cap rotor arm, throttle body ,cam sensor injectors , all to no avail ,
only thing to add is it drives ok if you keep revs up but just wont idle on its own,,after first start 12 seconds , even ran it up to temprature no difference, any ideas ??? thanks for any help in advance cheers paul
ive got a spare engine on standbywith allrunning gear inc gearbox ,but its all up fpr grabs as its not the same engine as the one in my seat its from a 3door ,ps im in croydon surrey
