Sep 30, 2019
11
Hello friend .
Since a long time Ive got Rattling noice from my wastegate on my 1.4TSI FR LEON , Could someone please give me the part number of the wastegate accuator? I want to order it on ebay , What does counts as a "good price" for this part?
thank you !!
Not sure you can buy that separately. Pretty sure it's one unit with the turbo.
But waiting to be corrected. :)
You cant buy the electric actuator separate.no way to refurbish too.
Are you sure my friend? So whats the reason that the 1.4tsi wastegates sold separately?
So if my Wastegate is dead I should buy an whole new turbo?
will the 1.4TSI(150Hp) will fit my 1.4TSI(122Hp)? Part number is
04E145721P
04E145721P
That is the correct part number for the full turbo, when looking for one I noticed that there are a lot of part numbers for the same turbo, they all fit the 1.4 and perform and look exactly the same just different part numbers. I have one spare in my garage with 96k miles on it, I can fetch you the part number from it when I'm home. Some turbos on ebay are cheaper than others depending on the part number but they're all the same part
All same crap sometimes new start rattle after few miles.no parts for electric actuator separately.
Thank you for the reply !
The intresting question is - Will the 150HP turbo is able to fit instead my 122hp turbo (engine code - cxs)
The only difference between the 122 and 150HP engines is the active cylinder function and a map allowing more power, the turbo is compatible between the 2 engines.
Reactions: Hellcat_11
I asked my mechanic about the "ANTI RATTLE CLIP" for the 1.4tsi , and he sent me this picture - will this help to solve the rattle???( the 2.0TSI HAS THIS CLIP!)
I've not seen or heard of this part before, if it's not too expensive it might be worth looking into
Today ive seen that while Iam using the Driving modes the noise is Stronger :(
Is it possible to fit IS12 turbocharger on 1.4TSI????
