Jm05cop
I am wanting a set of audi bbs alloys they are 19" and tyre size is 255/35/19 does anyone know if these are going to rub at all ? Or is any one running the same tyre size ? If so what are your opinions
Any help will be greatly appreciated thanks in advance
Jason
Jason
You sure that tyre size is correct? Cupras with 19's run 235/35/19 tyres as standard.
You need to find out the wheel width and offset but going by the tyre size of 255/35/19 I'd say they'll be too wide. That size tyre will also cause your speedo to under-read as the overall wheel & tyre diameter will also increase.
They're wide and with an offset that will poke out a fair bit. You 'might' get away with it on the standard ride height but I'd look for something else personally.
19 x 8 ET53 with 235/35/19 is the standard wheel & tyre size for a Cupra with 19's so that gives you a starting quide.
I think Cupra's on 19"s have an alteration to the steering to stop tyres rubbing.the turning circle is listed as larger than the FR
