I have a 2.0TDi (Altea) 140bhp, since buying it I’ve had problems with the turbo unit, it kept cutting out and moving to a turbo protection mode (similar to limp mode but you could hear the turbo spooling) eventually after around 20 visits to the garage they replaced the turbo control unit and hey presto – fixed.
No however, five months later, I have another problem all together. While driving along at low revs (i.e. cruising in 4th at around 30mph seems the most predominant at 1500 ish RPM) I get a hesitation that can only be associated with the kangaroo wobble that a learner driver gives with poor clutch control however not as severe. I maintain a steady foot (and on the flat) and the revs will dip by a few hundred RPM, and then return to normal a second later.
After reading the thread here: http://www.seatcupra.net/forums/showthread.php?t=290265 about the same sort of problem, I have bought one from SERE motors in NI for £2 in P&P to the UK. The thread mentions that it was designed by VW/Audi/Seat/Skoda to resolve the hesitation.
I’ve also read that while you’re at it you may as well clean out the EGR (Exhaust Gas Recirculation) and IMF (Inlet Manifold Valve) located right at the front of the engine between the radiator and the lump. But I have a few questions that I can’t find the answers to before carrying out a clean.
I’ve read that cleaning them with paraffin or carb cleaner etc seems to have broken a few EGR’s rendering them broken, if I merely remove any excess gunk (not back to clean shiny material) will this help the airflow? And not cause problems later on? As I need to save a little cash at the moment (as the car needs a DMF and Clutch which takes priority)
Would carrying out this task make the car sound less “laboured” as it currently sounds as if it is under stress to even turn on (like it has a load when it doesn’t) im hoping that this is the clutch/ Flywheel problem combined with the EGR gunk up?
And finally, I’ve noticed (with a little help from “toxic” on here) that the lower hoses in and out of the intercooler are oily around the seals… it’s been mentioned that this can cause boot problems? How to I remove to clean them? Do the pipes contain anything? Toxic mentioned that the oil would have travelled from the breather pipe; does this mean its gunked up too?
If anyone has any help or advice I would really appreciate it as im new to TDi lumps (and to turbo lumps) so have little experience of navigating them. So please fee free to correct me if any of the above logic is wrong, im expecting some of it to be.
Joe
Joe
