2008 (08) MK2 SEAT Leon FR 2.0 TDI PD170
Price
£1100 ono
Mileage
118270
Transmission
Manual
Fuel Type
Diesel
Location
Warrington Cheshire
Goot
There Can Be Only One!
Sep 9, 2002
394
Cheshire
BLACK, 6 Speed Manual, Diesel Hatchback, 2 Owners
118270 Miles as of 30/09/2025
MOT Expires 25/03/2026
2 Sets Original Keys
V5 - Log Book - Service Book - Owners Manual
No known fault codes stored, no error/warning lights.
Does anyone want a cheap run-around or maybe a project car?
Car is in need of some cosmetic TLC following change of priorities over the past 12 months.
Car used to be routinely hand washed, checked over and vacuumed monthly - went to adhoc cleans.
Since Spring 2025 I've noticed the issues after returning to my monthly car cleaning routine.
Car has mainly covered motorway mileage following the pandemic (using wife's car for short journeys) so healthy DPF regenerations and engine regularly getting up to operating temperature / cooled down correctly.
My car usage has significantly dropped since Summer, which makes it difficult to justify keeping a diesel for shorter journeys.
Car to be sold as a whole vehicle, no breaking of parts.
Known car issues noted below, along with car history.
Car serviced yearly [missed one year due to zero miles over pandemic]
Full Service History [Service Book Stamped, receipts available]
Last Interim Service: 04/2025 [117384 miles]
Last Major Service: 03/2024 [109465 miles]
Last Cambelt Water Pump: 06/2022 [101568 miles]
Car run solely on branded fuel and past 3yrs: Costco Premium Diesel
Archoil/OilSyn Fuel Additives added to every tank since ownership
Pre-MOT: Archoil/Oilsyn System Cleaner, Archoil Intake Cleaner
Engine Carbon Cleaned every 2yrs since 2019
SEAT 17" Alhioth Alloys [Refurbished, Powder Coated] fitted with 4x:
Goodyear Eagle F1 Asymmetric 6 225/45/R17 94Y XL Tyres
Tyre Tread: ~7.0mm front, ~7.5mm Rear
Space Saver Wheel with Original Accessories
SEAT Bluetooth Headunit
SEAT Premium Car Mats [Driver mat worn, rest very good condition]
Car Servicing History:
07/2009 - Car Serviced by SEAT [6377 miles]
07/2010 - Car Serviced by SEAT [14391 miles]
07/2011 - Car Serviced by SEAT [22754 miles]
02/2012 - Injector Recall, DPF Pressure Sensor by SEAT
08/2012 - Car Serviced by SEAT [32406 miles]
08/2012 - Cambelt, Water Pump fitted by SEAT Dealership
10/2013 - Car Serviced by SEAT [42369 miles]
12/2014 - Car Serviced by SEAT [52320 miles]
02/2016 - Car Serviced by SEAT [60994 miles]
05/2017 - Car Serviced by Indie Garage VAG parts, VW507 LL Oil [71264 miles]
05/2017 - Cambelt, Water Pump by Indie Garage VAG parts
07/2018 - Car Serviced by Indie Garage VAG parts, VW507 LL Oil [78924 miles]
03/2019 - Engine Carbon Clean pre-MOT
08/2019 - Front Brake Discs and Pads
07/2019 - Car Serviced by Indie Garage VAG parts, VW507 LL Oil [87654 miles]
10/2019 - Drivers Side Front Window Regulator
03/2021 - ABS Pump Unit Repair Kit
03/2021 - Engine Carbon Clean
08/2021 - Car Serviced by Indie Garage VAG parts, VW507 LL Oil [97196 miles]
08/2021 - Rear Brake Discs and Pads
06/2022 - Cambelt, Water Pump, Exhaust Middle, Exhaust Backbox by Indie Garage
06/2022 - Car Serviced by Indie Garage MANN filters, VW507 LL Oil [101568 miles]
11/2022 - Front Brake Discs and Pads, Front/Rear Calipers
03/2023 - Engine Carbon Clean pre-MOT
06/2023 - Car Serviced by Indie Garage MANN filters, VW507 LL Oil [106144 miles]
10/2023 - DPF Flash Cleaned OFF Vehicle due to high ASH content [DPF Specialist]
10/2023 - DPF Pressure Sensor replaced
03/2024 - Alloy Wheels Acid Stripped and Powder Coated [Silver]
03/2024 - Car Serviced by Indie Garage MANN filters, VW507 LL Oil [109465 miles]
10/2024 - Windscreen replaced due to crack
11/2024 - Ignition Switch replaced [VAG Specialist]
12/2024 - Lambda Sensor replaced, CAM Timing adjusted [VAG Specialist]
03/2025 - Engine Carbon Clean pre-MOT
04/2025 - Car Serviced by VAG Specialist MANN filters, VW507 LL Oil [117384 miles]
04/2025 - 4x Goodyear Eagle F1 Asymmetric 6 225/45/R17 94Y XL [fitted 117366 miles]
Known Issues:
Occasional diesel smell in cabin when car idling [started 04/2025]
Drivers Front wheel arch paint bubbling, paint starting to lift on bottom edge
Passenger Rear wheel arch small area paint bubbling
Bonnet Front Centre small area paint bubbling
Drivers Front seat showing signs of wear, bolsters beginning to sag
Passenger Front door occasionally pools water on door sill. Water can enter car if door not opened frequently
Some paint work scratches, stone chips and cosmetic wear and tear as you would expect from a daily driver of this age
£1100 ono was £1250
Andy
07771 661011
Front
Rear
Driver Side
Passenger Side
Mileage
Engine Bay
Front Seat 1/2
Front Seat 2/2
Back Seat
Boot
Spare Wheel with Accessories
Alloys and Tyres
Driver Front Wheel Arch Paint Bubbling
Passenger Rear Wheel Arch Paint Bubbling
Bonnet Front Centre Paint Bubbling
Loadmaster748
Los Dos Amigos
428
201
Surrey, UK
Good luck with the sale, £1250 seems a very reasonable amount for someone who wants a small project with some issues to iron out.
Reactions: Goot
Goot
Sep 9, 2002
394
Cheshire
I've had a number of questions (some I'm not 100% sure were serious):
1. What is the lowest price you'll take for the car?
Please make an offer based on what YOU think the car is worth. I won't be offended, but I may politely decline a low ball offer.
However I am open to offers, and will re-consider any previous offers once I've gauged interest in the car. You may get a bargain after all!
2. Would you consider a part ex, as I need to car downsize / expecting a baby / buying a house / lost my job.
No sorry, unless it's a 2024+ CUPRA Leon 300 VZ 2/3 with low mileage ;)
3. What exact fuel additives do you use?
Fuel Additive (each tank) I used to use: Archoil AR6900-D MAX, then moved onto Oilsyn Diesel Power DNA
System Cleaner (pre-MOT) I used to use:
Archoil AR6400-D MAX, then moved onto combination of Oilsyn CarbonCode Diesel Doctor, Oilsyn DPF & Turbo Doctor
4. Can you meet me at X, Y or Z?
No, if you are serious you will travel to me. Happy to pick up from any of Warrington's train stations.
5. Can you fill the car up with Costco Premium Diesel if I buy it?
More than happy to, but you'll need to pay for it either in advance or I'll take you on the day of purchase.
It's just a cheaper version of BP Ultimate Diesel or Shell V-Power Diesel.
Or is it the £1.50 Costco Hotdog and Soda you want? :unsure:
6. Do I need insurance to test drive your car?
Yes - whether that be covered under your existing car insurance policy, or temporary cover.
My current insurance provider doesn't allow me to drive other cars unless named on the policy, so please check yours.
I'll need to see evidence of insurance and your driving licence.
7. Can you drive the car for me, with me as a passenger?
I'm more than happy to! And no, it's not an odd request as I've done it before towards the end of a test drive in the past.
8. What payment methods will you accept?
Cash preferred. I'll consider bank transfer but only if it's from a bank account in your name.
No bank transfers from a friend / family member, and no to Paypal etc I'm afraid.
Reactions: tracktoy
