Hi FR_Power
I now have my DRLs fitted into the grilles, that you for your assistance, How did you route the cable through the bulkhead to the fuse box? Did you use an existing grommet, or did you drill a new hole? Does the grille surrounding the wiper assembly need to be removed?
I intend to use the "add a circuit piggy back fuse holder" similar to yours, but I cannot identify the cigarette lighter fuse, the fuse box is not numbered and there are two sizes of fuse!
Yes i used the existing grommet! no the grille surrounding doesn't need to be removed, there is a screw rivet on the side, you would need to remove that and lift up a little bit of the grille. In the manual it should tell you what the fuse is for the cigarette lighter.
