2013 Leon Mk3 Start Stop Issue
Willie1892
12
This has happened a few times in the last year.
Yesterday was in car park and let someone out to free a parking space - the car went into stop - no issues there then.
When I pressed the clutch - nothing happened, the display said something like .... manual start required.
I switched off the ignition and started the car by the key.
I know when the battery is below a certain voltage that it do not stop when at traffic lights etc but this was different.
Can anyone give me any guidance
Thanks Again
Willie
chrisRibiza
1,194
51
Did you remove your seatbelt when the car stopped as that will stop the car restarting automatically.
Willie1892
12
I don't remember.
The other times I would have, since I always reverse into my drive and always remove the seat belt before doing this.
Thus this could be the answer
thanks
Willie
chrisRibiza
1,194
51
Yeah, When I 1st got the car it took me a while to realise that I had undone my seatbelt which is why it wouldn't restart.
There is a bit in the manual which tells you the conditions which need to be met for stop / start to work.
W44DUP
73
West Sussex
Hi guys,
When I goto work (at airport) there is a security gate which I have to get out the car at and this also means that I have to manually start the car again. I always assumed that it was because I had opened the door but the seatbelt makes sense! Every day is a school day! ;)
ysfdncr
176
12
36
New Jersey, USA
Opening door, seatbelt and long waiting requires manuel starting. This is not an issue.
Samsung Galaxy Note 5 Cihazimdan Gonderildi
romster1
107
W London
Ive been having lots of problems wit the stop start. vehicle information screen states high power consumption as a reason its not working which Is BS as i even tried turning of the head unit and climate control and it still wont work. I know this functionality requires the battery to have a certain amount of charge but surly the alternator should top up the battery enough to keep this functionality available and working ???
Walone
1,559
429
Near Heathrow
I also have stop/start problems, I can do a 50 mile drive and it still won't work and I can drive a short distance and the engine temp only showing 2 bars and it works! It's load of crap and I can't help feeling that it's down to battery not being an 'AGM' but Seat cutting costs by fitting an 'EFB' one instead.
KXL
KXL
Dec 15, 2016
1,581
197
London, UK
Strangely, my car yday (very cold) refused to trigger start stop (but it didn't thrown any errors) for a good first 15-20 min of my 45 min journey. When it was warmer and I did the same..no problem...would start stop even after going less than 2-300 meters to the next traffic light from cold start.
It's only 1 year old, so I highly doubt the battery is the cause. But the last time I did drive it was about a week prior, this could be why.
How old are the batteries in your respective cars?
I do get 'restart the engine manually' if I open my door, or undo seatbelt once it has stopped.
Any other doors its not a problem.
Shaady
167
25
What did you have the heating set to?
Have found that if you put the heating up high (on the AC or just the blowers) the stop start won't function until the engine is up to temp, however if you turn the heating off it'll work fine pretty much straight away after starting it.
KXL
KXL
Dec 15, 2016
1,581
197
London, UK
Everything was at 0. I didn't bother turning it on as from experience, unless the engine temp is up to temp, there is no point, I cannot get any hot air anyway. Infotainment was also off. It was just me, and the car, no additional sounds (and luckily, no rattling either).
I wonder if the person's 2013 Leon's battery (4 years +) maybe just could not hold the voltage when it's cold like it used to (despite being in a thermal blanket in the engine bay).
romster1
107
W London
I'm aware that it wont operate until the engine reaches temperature but even when its up to 90 it doesn't work and like the previous poster in the past it would operate almost immediately at times. it has a life of its own the car is only a year old so the battery should be good
after a 72 mile roundtrip to the dealer it then worked for a day which leads me to still think its due to the alternator not keeping the battery topped up and charged. I tried arching this issue and found that some Skoda owners ( same group) have also been experiencing these issues too so could cost cutting on this part be the route of the issues ???
romster1
107
W London
Yea KXL i know it wont work with the climate control on which in itself makes it not fit for purpose we should be able to heat the car up when its cold and cool it down if its ever hot and still have the stop start functionality available and working
exmgman
76
8
Stop start
Have you ever considered what stop start can wear out.
When I got my previous Leon mk3 with the stop start Feature I questioned the Dealer Service manager as to what SEAT had done to modify the starter/ring gear to withstand constant restarts.
He told me nothing. So if the car is driven a lot in town traffic then the starter motor and ring gear will be potentially subject to high wear rates. I dare say it will probably last the warranty period but after that?
I always turn the stop start off and the Dealer service manager admitted that he did the same in his own Leon!
Reactions: Wastedagen
IrnBru
115
21
I'm getting a leon that should be at the dealers any time soon, but I had a juke before that for 3 years, it just became habit to turn the stop start off every time I entered the car, do you have to turn off the function every time you enter the car or does it stay off all the time? It just became second nature in the juke to turn it off all the time so it won't really bother me to do the same in the leon
Sent from my SM-G935F using Tapatalk
exmgman
76
8
Stopping stop start.
You have to press the switch to disable stop start every time you start the car.
I understand that it can be disabled by using the VW Audi software but the dealers are not allowed to disable this feature. I've asked!
This feature was introduced, and not just in VW Audi group cars, to reduce exhaust emissions to meet limits set by the EU in the urban cycle. In view of the diesel emissions cheating debacle it is obviously not something the official dealers will ever countenance even with petrol engined vehicles like mine.
6th.replicant
698
9
London
I’m contemplating upgrading my trusty Mk1 LCR for a used Mk3 LC or a Mk7 GTI. I’ve noticed some interweb rumblings about turbo failures for both cars.
Does Stop / Start cut the ignition if the turbo is hot, or is there a sensor that overrides the Stop function because it’s detected that a hot turbo needs cooling?
Ta.
Looie
25
Harlow, Essex
Personally I turn my stop/start off straight after I start the engine - every single time - can't stand the ruddy thing...... the 1.4ACT is so good on fuel it's a nonsense to have this on the car, but I do understand the 'political requirements' that force manufacturers to have them on engines.
It would have been a deal breaker for me when I was looking at buying a Leon FR if I couldn't turn the damn thing off.......... fortunately I could, and since buying the Leon 2yrs ago I am still very happy!
Wastedagen
478
101
Milton keynes
Stop start
Lol, the first thing I did once I received my obd11 dongle...
