Vanaaken
38
16
Scunthorpe
Car is lowered on Bilstein B16 Coilovers and currently has Forge 8mm spacers all round, it also has the R Line Stud conversion kit. I'd like to go wider on the rear (15mm) however it says that you cant fit more than 10mm with the stud kit, so was thinking of buying a set of 20mm spacers that bolt to the hub then install my studs into the spacer but will 20mm cause my tyres to catch (225/40 R18). I've looked all over and can't find 15mm spacers that bolt to the hub. Also the studs are chrome plated so have not been able to find any longer ones in that style which would have been the easier option!
