5000 to 6000 rpm
cupra collins
216
right i have just got my car revo stage 2 and im well happy with it apart from it seems to lose alot of power between 5000 and 6000 rmp i have a front mounted intercooler. changeing at 5000rmp seems to be the quickest way. JUst wondering what other peoples are like or if some can tell me what might be wrong
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
depends how much power its losing
have a search for old RR plots or vagcom boost logs,
you'd see that due to the limitations of the turbo, boost drops a fair bit and thus so does power, where you might peak at 21/22 psi or so initially, it drops to about 14 by 4500rpm, and then even lower to about 12psi at 6000rpm
fmic helps matters but its no miracle cure
Matt752
My car was doing something similar on stage one recently. I took it to BBT in Thurrock and the maf sensor had gone and a couple of engine hoses were shoddy, since they've been done my car's running like a dream again. Might be worth getting it checked??
Nov 2, 2004
9,335
South Wales
Vag com it to see if anything is up.
And remember the k03 is a tiny turbo and cant hold boost that far up the rev range.
Also, how long have you had stage 2? Its takes a few miles to adapt to the fuelling etc..
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
I think phil has hit the nail on the head, I found that stage 2 holds the power slighty better after 5000rpm, On stage 1 to me it felt like it wasnt even boosting at around 5000rpm onwards , Thats why its better to change at around 5k and not at the redline, Unless logging of course ;)
Get yourself a K03s that will hold the power better for you!
David.
Feb 25, 2007
657
stroud
im running my ko3s on standard jabba map im waiting for my full blue flame system before i go back to jabba
the ko3s is the best thing i have done to my car yet
cupra collins
216
i only got stage two saterday but iv done about 200 miles with it. im geting it rr in a week or so, so i will post the results. maf is ok ada new one about a year ago. i had some weird taque error that big boys toys didnt know what it was. they didnt like the N249 bypass either but there was no other faults. i got to change my vac hoses there a bit worn.
