6 Fault Codes Help
leoncupra2012
657
Further investigation into the new leon i bought yesterday ( 03 reg 180 AUQ remapped to 240 bhp stage 2)
Was sounding like a subaru under load, misfiring with the engine management light flashing.
Got vagcom working but only the lite version, these are the results. 6 fault codes found.
Google research suggest (as vagcom lite doesnt give full details)
16684 - Random/Multiple Cylinder Misfire Detected 35-10 - Knackered coilpack/coilpacks?
16688 - Misfire detected cylinder 4 - The culprit dodgy coil ?
17608 - (Boost Pressure Control Valve) N249 - This has been removed so thats ok.
18010 - Power Supply B+ Terminal 30: Voltage too Low - What the hell is this?, it had to have a replacement battery and there is a indicator bulb blown but nothing else electrical i know of?
16486 - Mass Air Flow Sensor (MAF/G70): Signal too Low - It doesnt have one its been removed? Theres just the hole where it used to be?
17763 - Cylinder 1 Ignition Circuit: Open Circuit Coilpack on Number 1 too?
Not too bad really. :)
SlimLCR
185
Lincoln
16684 and 16688 are one in the same, 16684 tells you there's a misfire, and then 16688 tells what cylinder.
18010 - if this hasn't been reset since having the new battery, reset and monitor. I had this code before Xmas and realised I hadn't reset it since fitting a new battery when mine died. It's been fine since.
leoncupra2012
657
Cheers, im pretty happy with that to be fair. I got 250 knocked off the sale price and if it costs me 60 or so for a couple of coilpacks and it runs fine ill be chuffed. Its got no maf on it and theres just a hole so i need to cover that up.. really odd !
