gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
My 8v GTI has been cutting out recently, not on a regular basis, maybe once every couple of weeks. But yesterday, it done it 5 times in a row! I've checked the leads, all seem ok, but what else should i check on my day off tomorrow?
Spark plugs?
Coilpack?
Coil?
For the last 2, is there any visual way of telling if the parts have failed?
crank sensor
with 2000+ posts i'd have thought you knew better?
search works, common faults & no end of threads all with the same suspects
I had a search, couldn't find anything concrete. How much am i looking at for a new crank sensor, oh knowledgeable one?
you'll never find anything concrete regarding electrical faults.
sensor price? god knows, depends on which you buy?
OEM £90 ish from memory? then the pain in the arse job of fitting it.
oil filter off, front engine mount i think from when garage did it, not much room down there.
Spark plugs?
Coilpack?
Coil?
mine was ignition coil pack
