8x16 ET35 on the front?
LomondGolf
After searching around for a bit, I see most people seem to advise no bigger than 7.5J on the front. My new wheels are going to be 8x16 with an ET35, will they cause me any problems on the front?
cuprachrissy
should be good as the standard are et 35ish, im running 7.5j with et 24 (like a 10mm spacer and have no problems at all, hope this helps.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
should fit. will be close, and if you have coilies the spring platform might be close to the tyres inner face.
Mine are 8x17 ET28 and ran 235-40 tyres, before arch mods. would rub as I was lowered
cuprachrissy
mine is on coilies too, slammed.
edit: they are 16's too.
LomondGolf
Alloys are fitted with 195/40 tyres and I'm only running lowering springs (previous owner so I'd guess a lowering of 35-40mm or thereabouts)
LomondGolf
Cheers for the replies, hopefully have a trial fit by the end of the weekend and all will go well. Will post up pics when I do.:)
Fingers crossed.
LomondGolf
Little update:
Its a snug fit behind the front alloys but they are on and have had a good run with no problems. :D The front only have a bit of lip sitting just slightly out from the arch, but I'm not running silly low that I'll have many issues. Rears are sitting lovely at the minute. 9J would probably suit better at the rear but I'm happy with it as is. Plus now I should be able to get passengers in the back compared to before, running Cupra alloys spaced 25mm.. the arches just sat on the alloys and there was no chance of it rolling.
So all in all, it looks so much better than I imagined. Very aggressive looking now compared to before. Car should be along at Inters at the end of the month with the Scottish lads so keep an eye out if anyone comes along.;)
cuprachrissy
Maybe stick a 10mm spacer on the rear to get a bit of poke? Good to hear u had no problems :)
