'99 Ibiza Cupra 8v Oil temp sensor
Cupramadhead
DEAR ALL
Hi I'm new here and the wife and I have bought a 1999 very YELLOW Ibiza GTI Cupra Sport 2.0 litre, 8 Valve, as our ahem.. family car!
Please could anyone tell us if the 8 Valve version of the Ibiza Cupra has an Oil temperature sensor on the engine?
I ask because we have the trip computer and all the functions work on it, apart from the Oil Temp, which would be nice to have! The Oil Temperature sensor doesn't give a reading, its just blank with dashes on the display. We drove it around for a while, to try and get the engine warm enough (according to the handbook, it only reads from above 50C) but after half an hour we still had no reading.
Please can anyone help? Thanks again.:)
old 'uns
Modern Life is Rubbish...
Mar 20, 2003
1,627
walsall
i'd hazard a guess as top of the Filter housing or somewhere close?
from memory there are 2 sensors, temp & pressure?
not seen mine for a while so can't look
Cupramadhead
Hi thanks for the quick reply! So the 8v Cupra does have this function then?
old 'uns
Mar 20, 2003
1,627
walsall
yes, as you said, scroll through the MF display temp is in there somewhere.
only reads above 50, normal running around the 90-95 mark?, been a long time since i've driven mine.
not too sure whether it has a thermostat in the cooler, as per the Rad? or it's permanently open circuit, maybe stuck open if so?
assume the engine temp is normal?
Cupramadhead
Yes engine temp fine. Do you have the 8 valve or 16v? Do you know whether either are particularly rare cars?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I think it's a single wire poking out there - but it's been a while.
That's temperature anyway. Pressure is somewhere else IIRC
Cupramadhead
Thanks, maybe I'll have a look and see if its disconnected. Thanks again.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
If it is - the wiring is pretty crappy and may well have kinked or degraded over the years
Cupramadhead
Hi
Had a wee lookie today and I've found a loose wire with a connector on, near to where I think the Oil temp sensor should be, but there's nothing to plug it into!?:confused:
There's three 'points' shown in your pic, where the plugs are, but one's got nothing in it. Going to let Seat have a look tomorrow, hopefully and hope they can shed some light on it. Hope this makes sense! Thanks again.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
The unconnected plug, is meant to be. I gave up looking for something to plug it into, but it was always present on all four 6K Ibiza's of various engine
Cupramadhead
Ah soo that's not the Oil temp sensor plug then??:confused:
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Unlikely
I'd find yourself a good local VW specialist. SEAT won't have a clue as it's not a recent model
Cupramadhead
Unlikely
Thanks again, I must say, Seat didn't sound too clued up when asked!:)
Cupramadhead
Have bought new oil temp sender, hope an pray it works!
On a slightly different subject, I have also bought a new standard fit, front spoiler lip to fit under the bumper. Only thing is, its come only with clip rather than the bolts needed! Any clues?
Cupramadhead
Hi Mork
Just got the oil temp sender today. Looking at your pic, please could you tell me which way the single wire you mention above is facing? Ie: is it at the front of the base that its on, facing the cars front or the back?
Also what does the other wire (connector) do? Thanks again!:)
Cupramadhead
It's at the front, facing up. Right by the oil filter IIRC
Thanks again. Geez I have fitted the Oil temp sender and bad news for me, no go! Nadda, nowt! Any clues as to why my friends? All it did was reset the figures for journey mileage, mpg etc but no oil reading. Went into town today with it and must have been reading well over 50c but nothing..
Old Un's said 'not too sure whether it has a thermostat in the cooler, as per the Rad? or it's permanently open circuit, maybe stuck open if so?'
Would this be an easy fix if its the stuck open circuit or crappy wiring...probably not I'm guessing?:cry:
Do you think a Bosch service centre would be a good place to try and fix this? Thanks again guys, really appreciate your help!
