ABS,ESP and tyre pressure light wont go out
kernal
hi all got this fault on my 56 plate leon fr the ABS,ESP and tyre pressure warning lights wont go out came on on sunday in the snow any ideas of a cure ???????????????????
darnell890
I had this problem last week. Took it to SEAT stealer. First they said it was front n/s bearing and abs sensor. Replaced at £290. 20 miles later same problem again. Took it back and was then told that master abs sensor needed replaced, this including labour cost £1000. Luckily warranty covered mine. Sorry if this is bad news for you.
Tfsi_Mike
2,387
Doncaster / Germany (Army)
Where are you based? Worth getting it scanned. I can't remember of SCN has a register of users with vcds
But I'm in Nottingham and Rotherham on weekends and can scan it.
All the dash lights come on if the battery has been disconnected but will go out after a short drive
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
Mike im in nottingham this weekend until tuesday
fancy a beer?
kernal
oh well back to square one changing NSR ABS sensor didnt fix fault ,still got same lights on the dash lit and same fault code . off to the local car electrics specialist on monday not happy
kernal
:help: oh well back to square one changing NSR ABS sensor didnt fix fault ,still got same lights on the dash lit and same fault code . off to the local car electrics specialist on monday not happy :confused:::cry:
Tfsi_Mike
2,387
This guy is in essex and has VCDs. A polite email and Im sure he will be happy to scan your car for a few beer tokens (Cheeper than dealer!) He is on the VCDs register over on Mk5GolfGti
HTH
chrisbassuk
kernal, you said replacing the NSR sensor did not fix your problem..
Did you manage to fix in the end?
thanks
kernal
hi yes got it fixed by a local auto electrics specialist turned out the ABS brain connector and multiplg where corroded ,,they cleaned the conections up ,tested and re calibrated it no further problems :D
chrisbassuk
Thanks for that need to order a sensor get it changed ;-)
malcolmquinn
Hi there. I have the same fault. I have previously changed one of my speed sensors (Altea XL Stylance TDI 170) and this fixed the problem. I live in Doncaster. Could anyone offer a scan...I'm planning to do the repair myself this time and not rely on a garage! Thanks in anticipation
