ABS TCS and Bracke light on and beeping all the time and the fault code is 00668 anyone els ever had this??
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
I am getting this error now. TCS and ABS lights on from startup then 3 beeps and handbrake light flashes as soon as i start driving. Started happening after i disconnected the battery the other day and cleaned up the positive connector with wire wool.
I have cleared the fault with VAG-COM and when i do th auto-scan now it says 'no faults found'. However the lights are still there, and it still beeps 3 times on startup!!!![]()
Which 2nd fuse did you change/where is this fuse? The one on the battery?
