RWP
Jan 4, 2022
Hi all,
Hoping someone might have some insight into a persistent AC issue I’ve been dealing with.
My AC has been looked at by a couple of garages and re-gassed twice this summer. After each regas, both sides blow cold air as expected. But after a couple of weeks, the problem returns: the passenger side (RHD) starts blowing warm/hot air, while the driver’s side stays cold-ish.
One garage mentioned the system “holds pressure for longer than is usually tested,” which makes pinpointing a leak tricky. When the issue reappears, I hear a very noticeable hissing noise from inside the dash - but only when the AC is turned on. This noise isn’t present immediately after a regass. I have a video, which I'll try to attach.
I’ve tried resetting the AC distribution doors countless times and even removed the interior panels around the centre console to inspect the actuators. From what I can see, they seem to be moving correctly.
It’s becoming a bit of a mystery, so if anyone has experienced something similar or has suggestions on what to check next, I’d really appreciate it!
Thank you
2018 1.4 Leon FR Technology
If the regas resolves it temporarily then there is a leak. No amount of messing with the flaps is going to change that. The hissing might be the gas boiling in the heat exchanger as it gets low.
Reactions: RWP
When they say 'holds pressure' what they probably mean is it hold a vacuum - as the machine will pull a vacuum and wait something like 10 mins to check for leaks.
This isn't the best - as it really should be tested under pressure to check for leaks - as the AC systems works under pressure. This is done by pressurising the system with nitrogen - but takes longer so is seldom done.
This hissing you hear is a sign it is low on gas - so you have a leak. They also should add dye so you can check where the leak is.
Reactions: nd-photo.nl and RWP
Thanks everyone for the responses!
I have service coming up so I think I'll have them replace expansion valve (can't be too costly?!) and re-test for leaks.
