stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
tried to switch off (well minimise) my EGR settings , into engine block , adaptions as per usual, and i get this
this appears on all channels
the only channel that i see anything usefull is 2 but that doesnt seem to do anything
any ideas why this is , it wordks perfectly in central conv. for example, beeps on/off, internal sensors on/off ,
also wat is the group for the EGR on the PDs,
excuse the desktop picture on my laptop, im so anal :whistle:
cheers as ever
stephen
EDIT do i need to "log in" for this , wat code do i use
Yes, the ECU requires a login before it will let you access those channels. THE code is 12233. But please be CERTAIN that you know what you're doing; that the channels on your PD match the ones that are typically documented for the distributor-pump engines. You can do a lot of damage to a TDI by tweaking the wrong channel too much.
-Uwe-
