Address 09 cent. elect. cannot be reached
Jackie
Hi to all..
I have a 10.6 vag cable and just open some settings. ( coming home , welcome mode etc. )
I'm certain I didn't touch anything other than a couple checkboxes . But now when i scan it,it gives 2 fault ..
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 113B401209220002880E02EB901C00403400
Shop #: WSC 04941 000 00000
VCID: 74ECDE8E28E139BC
1 Fault Found
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 186
Mileage: 21753 km
Time Indication: 0
Date: 2020.14.04
Time: 19:28:12
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 397
Count: 50536
Count: 0
Count: 0
Count: 0
Address 09: Cent. Elect.
Cannot be reached
Address 46: Central Conv.
Cannot be reached
Waiting your help..:confused::confused:
Jackie
I can't enter the "Select Control Module".. What should I do?
Feb 26, 2009
5,275
Wolverhampton
The only thing I can think of for the 'cannot be reached' codes is the quality of your lead, is it an Ebay special or an official lead?
As for the tyre pressure fault, perhaps it's worth checking your tyre pressures?
Jackie
But i use it smoothly before..
I think wheel changing causes tyre pressure fault ..
And firstly address 46 is ok , but then cannot be reached.. i can't understand
Jackie
Ok I find the problem..
Note: If this module does not communicate, unlock all vehicle doors and try again.
I tried and it works..
But i can't enter the 46 cent. conv.
Any ideas?
